Knowledge is limited on these. Will a TS760 Ign adapt with a swapped out module?
They can, I've done a couple in the past and what you do is use the "Mega Fire" trigger which is unlimited and that makes a good running saw.
Atom also makes a trigger which works with the 760 ignition, I think it's the brown-coded one. It's the trigger unit for the 760 which limits the
revs, so once you eliminate that, you have an unlimited ignition. So I could use a 510/760 ignition.
