390 vs 372
parrisw
141
BC, Canada
Finally got around to running my 390. This is just the first run, on a brand new top end, so still a little tight yet. I think there is more in it, it was ported conservative for the first time in a 390. For those that haven't seen the vids on AS.
Same bar and chain, swapped between the two. 390 wearing a 8pin, 372 has 7pin.
[video=youtube;pb96p_Xoajk]http://www.youtube.com/watch?v=pb96p_Xoajk[/video]
[video=youtube;Vpkd-Xh30tU]http://www.youtube.com/watch?v=Vpkd-Xh30tU[/video]
parrisw
141
BC, Canada
Will the 390 just dosnt sound like its running as free as the 372 are the #'s between the two dramatically differnt?
You may wanta work on the 372 carb sounds like the needle maybe leaking a bit ...
I have done 2 390's and I think both owners will tell ya the 372s wont get a smell...
Ya I hear ya, I thought the same thing. I said over at AS that the 390 doesn't impress me like the 372 does. The 390 timing is unchanged except for what the machine work had altered it, I think the ex was at 165°dur. The 390 has higher ex, I think that 372 is only 162° dur on ex, 160°dur intake, and maybe 120 atdc on the transfers. The 372 had much more transfer work then the 390, I didn't really touch the 390 transfers much at all, I widened the uppers a little that was it, and slightly opened the lowers, I was figureing I was going to have to go into the 390 again, just wanted to take it easy since its my first time in one.
The 372 is more broke in then the 390 as well. The 372 is set about 1000rpm higher as well.
How can ya tell by the sound of the 372 that it needs carb work?
parrisw
141
BC, Canada
The 372 sounded really loaded up when you picked it up to run it.
That's normally a sign its leaking a tad...
OH, ok, It's done that only when cold, I had just started it about 30s prior to starting the video. Although, its been worse the last two times. I'll give the carby a check over.
Any tips on the 390? I was planning on putting a few tanks through it then going from there. I've just heard they like much different porting then 372's, so I'm going slow till I figure them out. Sorry I accidentally deleted all the PM's we shared on AS about the 390's.
parrisw
141
BC, Canada
Well will I suppose thats depends on what kind of porting you put in your 372's....
I brought the ext port down to 98* left the intake and raised the transfer to 120*
Ok, thanks. Sorry I'm bad at remembering #s on the saws I've done. Its all documented over on AS in my build threads though. That 372 is the best one I've done so far, and getting ready to do another.
parrisw
141
BC, Canada
Hey Eric I went back and looked what the 390 numbers were at.
EX 97.5atdc 165dur
Intake closes 76.5ftdc 153dur
Transfers 121atdc
Blowdown 23.5
I was thinking that the transfers can come up 3° to start. With lowering the cylinder, I did loose some transfer time/area, and I only widened them a little, so I did loose some transfer. Going to run it for a few tanks then take it back apart. I also think it needs more intake, I may lower the cylinder more to get more compression too.
blsnelling
Slower than stock porting specialist
166
43
EX 97.5atdc 165dur
Transfers 121atdc
Blowdown 23.5
I would raise the transfers 3 and drop the intake 8. No, that isn't a typo:)
blsnelling
166
43
[video=youtube_share;3vT4DeVoyd0]http://youtu.be/3vT4DeVoyd0[/video]
Not to distract but I gotta ask - What's with the fluttering in RPM's in some of the cuts? I hear that elsewhere as well sometimes, but it caught my attention in the 390 vid. Not so much the 372, definitely on the 390. Not everytime but some cuts it had that fluttery sound to it, rapid fluctuations in speed almost like a grabby chain or something but the saw doesn't appear to jerk around at all.
4,359
That's the "sweet spot":thumbsup:
parrisw
141
BC, Canada
Ya it's the chain.
B Need a Rear Handle for a MS290/310/390 Wanted 1
J wanted 385 or 390 builder Wanted 0
Black Dog Chainsaw Farmboss 290/390 crankcase/tank Wanted 0
Barneyrb 346-385/390 Wanted 11
B Stihl MS 390 Cylinder Wanted 1
Chity_Avatar Stihl 290 and 390 piston question Chainsawz 4
Termitebuffet Husky 390 oiler Wanted 21
Chity_Avatar Stihl 290, 310 and 390 differences Chainsawz 60
PA Dan Bailey's 390 kit build... Chainsawz 48
Tramp Day wager 390 Husky for sale For Sale 3
jrcat 390 or 394 used Wanted 5
mweba Ms290 310 390 Am kits Chainsawz 8
Black Dog Chainsaw Dolmar/Makita 401, 390, 341, 100, 102 etc Mods. Chainsawz 1
SKEETER McCLUSKEY 390 husky For Sale 7
mweba Stihl MS290 310 390 Repair Hawgz Garage 5
E 385/390/395xp really wanting a 395 Wanted 2
StumpysCustoms 029, 290,310,390 buildoff. GTG'z & Eventz 21
dieselfitter Wanted Junk Husqvarna 365 372 Crankshafts Wanted 26
F 372 xpw Woodz Porting & Saw Buildz 9
T WTB: 372 full wrap handle Wanted 3
T 372 cylinder cover For Sale 0
T Husky 372 P&C For Sale 4
R Roncoinc chinee 372 BB build Chainsawz 131
stihl for life ported 372 xp Wanted 3
Wigglesworth Husqvarna 372 For Sale 12
naked arborist First 372 extra pee for me Chainsawz 16
W Husky 365/372 question.. Woodz Porting & Saw Buildz 7
Jimmy in NC 365/372 HD Filter - Convert Low Top to High Top Wanted 2
F 372 felling dog Chainsawz 1
W A day in the woods! Spike60 & W'dog Run & Discuss Husqvarna 372 Aftermarket Parts Series "Test" saws Woodz Porting & Saw Buildz 11
W Huztl 52mm Big Bore (75cc's) vs. Husqvarna 365 / 372 Hybrid & some comments on this series Woodz Porting & Saw Buildz 2
W Huztle 372 aftermarket build vs a poor Husqvarna 455, which cuts faster? (Video, some cookie ) Woodz Porting & Saw Buildz 5
W Huztl Aftermarket parts for 365/372 series Husqvarna's Hawgz Garage 12
C I wants a jred 2166, 0r 2171 or husky 372... whats the difference? Chainsawz 32
W Quandry, Huztl 372 "Big Bore" build Woodz Porting & Saw Buildz 16
BloodOnTheIce Aftermarket Husky 372, 365 Stihl MS440, MS390 Pistons and rings For Sale 2
Chity_Avatar Husky 372 question Chainsawz 34
jrcat WANTED 2 full wrap handles for 371/372 Wanted 0
Chainsawwhisperer Looking for 372 parts... Wanted 8
komatsuvarna WTB 372 case Wanted 2
Termitebuffet 372 xtorq Woodz Porting & Saw Buildz 19
T 372 piston and cylinder? Chainsawz 11
jacob j. 362/365/372/372 crankcase Wanted 3
Cut4fun Trade 268 clutch cover for 365 372 clutch cover Wanted 1
BloodOnTheIce sold - Husqvarna 372 Muffler Gas Race Saw - sold For Sale 12
mweba How to change a 365 x torque into a 372 Hawgz Garage 16
parrisw stock441/ ported 372 comparison Woodz Porting & Saw Buildz 14
WoodChuck'r 365/372 (xt) Chainsawz 84
