60dl gtg chain
Status
Not open for further replies.
I'm going to sell the 60 dl 3/8" .050" chain I did for the chain build on competition saws. It's not thinned and should work good for a ported 90cc saw. $60 or make an offer.
Mike would you suggest that it be used on a 5 cube as a practice/play around chain or is it done up a bit more for actual competition stuff......???
It could be used on a hot 5 cube. It's not a thinned race chain. It's a nice cutting chain on a stock 3120. If I had some poplar here at home I could test it on my xpw.
Sounds like it might be pretty aggressive for a woods ported 5 cube'r.
I might be interested if it doesn't pull the motor way down. I just have some cants lying around and one of these days I might wanna have a chain to play around with. I stick to using a 7pin though so it might be alright to use. Thing is though I always pull the motor down from my fat ham hands anyways so if that chain is too aggressive I just may stop the saw in mid cut, lol.....
I can test it on my xpw and let you know how it does. I can grind a little more off and make it less aggressive for you.
Sure Mike if you can make it a bit less agressive for a 5 cube I'd buy it off ya.....
I can make it work for you Jason. I'll test it as is and then see if it needs any changes.
Status
