88 Ford Coolant Capacty
cat-face timber
Recycled Tampon. Just wring 'em out.
Jun 25, 2014
3,145
21,654
Northern Arizona
In my 88 FORD 7.3 L Diesel, how much coolant is required for a full coolant change?
I know that I should just buy a book, which do you think would be my best bet?
Chiltons? Haynes?
Thanks
bigbadbob
Ewe turn me on
Dec 9, 2015
11,991
115,884
Up Norf
It must be 8 US,, and I think you need to add the stuff to stop block cavitation.
You dont need no pin hole in a cylinder wall. The 7.3 diesels in comercial applications had a coolant filter, it was impregnated with the stuff to stop the cavitation.
A test strip comes with the stuff,,
Am not 100% sure if the 88 need this stuff.
BBB
Reactions: 4 people
olyman
4,743
20,750
One gallon of antifreeze
One gallon of water
One gallon of water
One gallon of water
One gallon of water ....
Zoo City Sawz
not in iowa..nor minnnehahahahaaaa...mix strongest possible. as on 30 below mornings,,with LOTS of wind,,you need the coldest mix possible!!!
Steve NW WI
Converted to the Dark Side
Aug 3, 2013
5,656
51,167
Star Prairie, WI
If you think Termites' way through, itll always be 50/50 or stronger - as long as you start with the antifreeze first.
Ive done it that way many times on big systems.
10,734
68,508
You'd have to think.
The first couple of gallons of water could be 3/4 gallons, then it would be a bit stronger.
Good in the winter cold, but not so good in the summer.
Which is why they sell it 50/50. Good enough for the continental US.
