88 Ford Dual Battery Issue
cat-face timber
Recycled Tampon. Just wring 'em out.
Jun 25, 2014
3,254
22,649
Northern Arizona
So I have a 88 Ford with Dual Batteries.
I think both batteries are failing at the same time, or the cable that Daisy Chains then together is going bad.
My Question is, do you make your own cables or do you buy one?
I priced it out to about $120 shipped.
If you make your own, where do you get the terminals? The battery cable on the passenger side has the strange terminal.
26,842
194,593
Strange terminal?
https://www.waytekwire.com/products?clear=true
Aug 27, 2013
16,931
75,740
Last one on a Ford we did... '86 F250 with dual batteries we had the cables built at Batteries Plus in town. I don't know if one is local but they made some top notch cable just like the original, but with better wire while we waited. Truck turned over better than the owner had ever known.
I think this is the terminal that you would use to build it.. or something very close. If you don't have a crimper, I'd have them built local.
https://www.waytekwire.com/item/36326/4-0-GA-Crimpable-Battery-Lug/
nitehawk55
1,788
5,309
SW Ontario
Take the batteries out and test them to see if the cells are OK .
The cables are a simple parallel circuit and pretty simple to fabricate with some help from a knowledgeable fellow at a parts counter .
I'd gladly come down and do it but just a bit too far away :D
cat-face timber
Jun 25, 2014
3,254
22,649
Northern Arizona
SW Ontario and N Arizona..
yes quite far.. thanks for your help!
773
1,792
I always solder those anyway. Put them in a vise, heat with torch, melt solder inside them like a crucible, then stick the stripped wire into them.
For extra professional results, only strip 3/4 of the cable you intend to put in so the cover melts into the edge of the terminal. Also use 3M or any adhesive lined heat shrink around the connection.
Reactions: 6 people
Fifelaker
I can almost see Genius' mushroom cloud from here.
16,358
133,875
Fife lake,Mi
If you use acid, neutralize it with baking soda and water. Make a paste, brush it on and wash it off with water. http://www.oatey.com/products/copper-installation/flux/no-95-tinning-flux I use this for everything any more. It is made for plumbing but it works on everything I have tried it on. I did a test on 1/2" copper pipe years ago, I cleaned the pipe and brushed it on the pipe and fitting, then heated them up. I opened the valve and it held water. I did bleed it down and add solder, but it held without the additional solder. It also works with 50/50 and other alloys.
Reactions: PRJ
Aug 27, 2013
16,931
75,740
Do that regularly on equipment. Holds better on vibratory rollers than crimped ends. Since they are crimp on ends...for ease of posting I just went with it.
cat-face timber
Jun 25, 2014
3,254
22,649
Northern Arizona
Thanks for your help Bud and Jimmy!
Question for you..
What Gauge would you use for the main crossover cable? That goes from Positive to Positive?
olyman
4,860
21,420
Crimpablet Battery Lug 4/0 Positive Right Angle
that's commonly called a flag terminal. I know the thread is old...
