Ammo handloaders
deerjackie
WEST TN.
Any ammo handloaders in here? Any of ya ll got a good technique for determining oal on rifles with bottleneck cartridges and is .005 off the lands sufficient?
MacLaren
Mike (mdavlee) is hand loading Jackie.
He's in Knoxville right now, but will be back shortly. He might be able to help ya. What caliber are ya loading?
Hedgerow
Mizzurruh Saw Gangsta
The closer you can get your projectile to the lands the better. Just no touchy...:ahah:
Is this a bolt gun you're loading for?
I set each round with a micrometer and a machined piece that sits on the shoulder of the bullet.
deerjackie
WEST TN.
Has anyone used a stoney point oal gauge with the dummy threaded rounds?I have tried the unsized case with lipstick method but that doesn t give a good reading.I have this idea of drilling the flash hole and inserting a rod with o rings and the bullet that i am loading at the time to check the guns oal then subtract .005 from the caliper reading and record that number and see how that works.I know a lot of folks who use the saami standard when handloading so they fit all guns but i like to tailor each load for each gun.
Hedgerow
Set a bullet in your case but only part way... Color bullet with sharpie... do not crimp, just load round into gun and slowly close action. Open action slowly and remove round. Measure for overall length and reduce by what you feel comfortable with. The lands force the bullet into the cartridge. So you know what measurement "touch" is... Go from there...:internetpartytime:
What bullet are you using? I know sierra recommends a little jump of .010" or so. Loading different depths is something I would do after I find a powder charge that does good.
Hedgerow
With that case, I've always had good luck with IMR 4350 as a propellant... May be something better now, but I'm a little outdated...
I've exceeded the maximum suggested load by a few grains in the 270Win.
deerjackie
WEST TN.
I am still using accurate 4350 from an 8 lb jug i paid 65 dollars for , that was cheap even back then, 99 i think.
A lb jug is going to make about 75 rounds for the 338 lapua I got. It shouldn't take long to find out if it likes retumbo or not. I'm going to try h1000 next. Brass is the killer for this round $2.50 a pop:eek:
I know a guy with a whole pile of brand new loading stuff, who can't get to it cause there are so many saws in the way....
I suppose finely ported saws would be sufficient when the Zombie Apocalypse begins, although I would like a little room in between me and the undead. :chainsaw: Just sayin
We need a Zombie banana, Chuckr
deerjackie
WEST TN.
How are you liking the 6.5 creedmoor? I have heard nothing but good from that cal , just hard to get away from 25-06.Maybe i need a tc pro hunter in 6.5 cm and add more barrels.
I like the round just fine. I wish I had bought it in something besides the ruger. I like the savages a lot better overall. I'm going to sell it to fund the reloading and a first focal plane scope for the 338. I think I'll get another rifle in the 6-6.5mm class later on. The ballistics of them are flatter and less wind drift then the 308.
deerjackie
WEST TN.
Rugers have hard triggers,other than that i love them, mine is a skeleton stock and has killed enough stuff to strain a locomotive.
Hedgerow
270 WSM.... Try it... You'll like it...
Hedgerow
Ruger arms are built strong, rugged, and I love em'... That being said... I own only savage rifles... Utility and accuracy are paramount with the savages... I love the accu triggers, but own them without, and don't care. I can overcome a lawyer proof trigger, but can't do anything with a squirrelly barrel... My 44 is a Ruger... Period...:wink:
