Bar I.D.
I found this among the stuff I brought home last week. In the dark of the shed I thought it looked like the D076/176 mount for the 10 Series McCulloch saws but as you can see, it is not.
Any idea what it will fit? It is a 28" Oregon with the single rivet nose, you can't see the nose but from the numbers someone will figure it out.
If it looks like something you could use, send a PM.
Indianola, Iowa
how wide is the stud slot mark? 9-9.2mm would make me think D009 Large Husky mount, if so it would also fit larger Dolmars. If it's 10mm it's the old Jred mount but the chain tensioner holes look to small.
Indianola, Iowa
Just checked my reference guide.
3/8, .058, 93DL, D009
will fit the following...
Dolmar PS-6400, PS-7300, PS-7900, PS-9000, PS-9010FL
Efco 181 (Newer Models from Aug 2007+), MT 7200, MT 8200
Husqvarna 61, 65, 66, 70, 77, 160, 162, 181, 185, 260, 266, 268, 272, 281, 285, 288, 288 Lite, 298, 365, 371, 372, 380, 385, 390, 394, 395, 480, 562, 570, 575, 576, 1100, 2100, 2101, 3120, Jungle 3120
Jonsered 625, 630, 630 SUPER, 630 WEST COAST, 670, 670 WEST COAST, 2065, 2071, 2077, 2083, 2094, 2095, 2163, 2165, 2171, 2186, RIPPING MILL
Makita DCS 6401, DCS 6800, DCS 7301, DCS 7901, DCS 9000, DCS 9010FL
Partner 550, 650, 1655, 2055, 7000, P-55, P-65, P-70, P-85, P-100, R-11, R-12, R-14, R-16, R-17, R-18, R-19, R-20, R-21, R-22, R-23, R-30, R-35, R-40, R-416, R-420, R-421, R-435, R-440, S-50, S-55, S-65
Poulan PRO 415, 425, 445, 475, 505
Shindaiwa (SDK) 550, 575, 577, 680, 695, 757
Solo 603, 662, 665, 667, 670, 675, 680, 681, 690, 694
I have some shorter D176/D076 bars if you are in need, and I can always use more D009 mount bars... You can also use a (1.2-1.5mm in total) "S" clip adapter and it will fit on D176. You can open the bar stud holes and might need to check oiler hole alignment.\
Hope that helps!
nate
