best chain for all around? dirty and clean wood mixed, lpx or lgx?
cobey
1,160
605
i run full chisel now, got a loop of the semi. what do you guys use?
btw...what kind of chain is woodland pro? thanks
im running .050 3/8 60 drivers, on a 5020av, 360 homie, and a 500evl
bryanr2
193
76
Full chisel cut the fastest but dulls faster if in dirty wood. All chain dulls fast if it hits the dirt. Semi doesn't cut as fast but last longer between shapening. Woodland pro/ Carlton rebadged? Not sure on that one. Im thinking of running some semi on a few of my saws.
komatsuvarna
952
South East TN
Unless your dead set on cutting the fastest, i think semi chisel is probably the best all around chain. Last longer between sharpening, but more forgiving in dirty wood.....you do lose a bit of cutting speed.
Reactions: 4 people
roberte
Latte Lover
Sep 30, 2013
62,411
487,408
given a choice, i'll stay away from the dirty stuff. If I know it dirty and no choice, I use a chain that's at the end of its life
38
My favorite work chain is 3/8 050 full comp Stihl semi chizz.
Easy to sharpen, and it lasts a long long time without needing a file run through it. Just cut and go, definitely a low maintenance chain for my needs.
Reactions: 6 people
47,584
Semi chisel for bucking dirty wood and square ground chisel for falling.
773
1,792
I'm fortunate that I'm usually cutting clean wood so it's full chisel square ground most of the time. If I'm cutting a lot of stuff that has been dragged or cutting firewood in a flood plane where the bark gets a lot of sand in it then I'll switch to semi chisel because square grinding a beat up chain sucks!
Reactions: 4 people
14,449
70,160
In your title you mention "LPX or LGX". Is it your understanding that one's chisel and the other is semi-chisel? That's what I gather from your post. BOTH those Oregon chains are chisel ('full chisel'). JGX is full skip chisel. Main dif between LPX and LGX is that LPX has small bumpers to make it cut 'smoother' and act as somewhat of a kickback reducer.
Oregon semi-chisel is DP, AP, APX, or DPX (as in 72DPX, 73DPX, or 75DPX). AP and DP have been replaced by the 'X' versions. Same with LP, LG, and JG.
http://www.loggerchain.com/100-REEL-72LGX100U-Oregon-CHISEL-CHAINSAW-CHAIN-SALE-72LGX100U.htm
http://www.loggerchain.com/100-72LPX100U-Oregon-full-chisel-saw-chain-3-8-375-050-72LPX100U.htm
http://www.loggerchain.com/100-72JG...n-3-8-050-full-skip-full-chisel-72JGX100R.htm
http://www.loggerchain.com/100-72AP...ll-Skip-Semi-chisel-3-8-375-050-72APX100U.htm
http://www.loggerchain.com/100-72DPX100U-Oregon-semi-chisel-saw-chain-3-8-375-050-72DPX100U.htm
Reactions: 4 people
I prefer chisel chain.
Woodland Pro isn't even rebadged Carlton, at least the ones I've seen. Drive links are stamped the same. Tie straps are not marked. It's real easy to burn on a grinder, definitely a lower grade than the actual Carlton chain.
I'm not up to speed on the cost of Stihl chain, but other knockoffs can't really cost so much less than Husky/Oregon to make it worth it, no?
Reactions: 4 people
47,584
I prefer stihl chain if the price is right. If not I'll use Oregon. If I'm square filing I prefer the Oregon anyway.
SawTroll
353
Troms, North Norway.
In your title you mention "LPX or LGX". Is it your understanding that one's chisel and the other is semi-chisel? That's what I gather from your post. BOTH those Oregon chains are chisel ('full chisel'). JGX is full skip chisel. Main dif between LPX and LGX is that LPX has small bumpers to make it cut 'smoother' and act as somewhat of a kickback reducer. ....
Yes, but the LGX also has a kickback reducer, namely the large ramped rakers, like Stihl RS/RSC. The result is that the LP/LPX cuts smoother (and a little faster), with about the same level of kickback protection (all are "yellow" chain). :)
14,449
70,160
Yep. I have a few loops of LPX and like it.
38
Does Oregon still make that "untreated" LGX chain....?? I remember them hyping it up quite a bit. I had a couple loops and thought it cut alright but at no point did I think it brought something all that great or new to the table.....
cobey
1,160
605
thanks, i asked the chainsawr guy for semi chisel.... dang it..... thanks for all the replys
C whos got the best price/value on 13" or 15" guide bar and chain for my 024 stihl ??? Chainsawz 18
Mastermind Who has the best prices on rolls of chain???? Chainsawz 33
Mitch95100 Best Chain Sharpner Chainsawz 13
Mike from Miami What chicken is best? And which special sauce? The Razorback Lounge 16
trx250r180 What Chainsaw Oil Is The Best ? Mix And Bar Oil Chainsawz 148
Freehand Best Place To Get A 660 Pissin' An' 'Rangs? Hook A Brother Up/Mindless Banter Welcome. Chainsawz 15
Freehand The Best Tool Reviews On The Web Hawgz Garage 10
C who would be the best to get bearings and gaskets for my 066? Chainsawz 14
Sprintcar Best Weather Map Ever The Razorback Lounge 19
N Best piston choice for 084 60mm piston . Had a Golf bust on a saw !! Chainsawz 21
W This is a rehash I'm sure.... But WHAT is the best Woodz Porting & Saw Buildz 2
W A motorcycle guy's (one of the best) overview of Two Storkes & Porting Woodz Porting & Saw Buildz 0
SKEETER McCLUSKEY the best people on this forum The Razorback Lounge 5
Chity_Avatar The best people are on this forum The Razorback Lounge 76
C whats the best way to find a Dolmar dealer in my area? Chainsawz 9
Virgil Best country to move to? The Razorback Lounge 75
BloodOnTheIce Best Ipad for.... GeekHawgz! 9
Chity_Avatar 50cc-60cc Saw with the best modability Chainsawz 80
jrcat Who has the best moobs The Razorback Lounge 67
4 best new saw available for under 400.00 Chainsawz 28
Little Possum best sawhawgz approved phone case GeekHawgz! 19
Jordan3605 The Best Kept Secret Chainsawz 21
C whats the correct or best way to mod a jred 2159 muffler? not ported work saw Chainsawz 41
M Oboma: 5th Best President Ever The Razorback Lounge 10
Genius Best direction to stack wood Hawgz Back 40 29
C where is the best placeto get intake bootsfor a 360 homelite?? Chainsawz 2
WoodChuck'r Hi what's the best chainsaw for cutting up wood into smaller pieces. Chainsawz 16
de_dubya Best Friends (as in man's) Post 'em up. The Razorback Lounge 7
Nixon Chain question . Chainsawz 52
trx250r180 Stihl usg round chain grinder For Sale 9
cat-face timber Homelite Super XL 925 Bar/Chain Wanted 3
Nickolas Chain parts and pieces Wanted 0
N .063 gauge .325 chain , is it common in the USA ? , I need some Chainsawz 26
2broke2ride ID this chain please Chainsawz 3
N Word is Blount / Oregon chain / bars has been sold Hawgz Back 40 24
S Makita 6401, sugihara 32" bar, how long of a chain? Chainsawz 9
mdavlee Race chain for Jeremy and Shauna Chainsawz 6
Cut4fun Chain build off GTG'z & Eventz 8
Majorpayne Handling Bulk Chain Chainsawz 58
H Chain geekery: Chisel Ground vs Chisel Filed Chainsawz 21
G Need 32" bar and full skip chain Wanted 8
ft. churchill Timberline chain sharpener Chainsawz 5
P Menard's Chain Prices Chainsawz 25
B Wanted 3/4 harvester chain Wanted 7
Magnumitis Chain grinder Hawgz Garage 39
DefinitiveDave Franzen sharpener, stihl service clinic, safety chain, counterfeit saws, etc. Chainsawz 31
C Chain Saw Industry magazines Chainsawz 1
B General 60 inch bar and chain for Homelite For Sale 1
BloodOnTheIce Homelite 340 with 16" bar and chain For Sale 5
BloodOnTheIce New 36" Stihl .404 .063 Semi Chisel Full Skip Chain For Sale 3
