Cleaning a Air Filter Question
cat-face timber
Recycled Tampon. Just wring 'em out.
Jun 25, 2014
3,458
24,403
Northern Arizona
Here is a pic of my Air Filter off of my Husky 385 XP.
I replaced it with a new OEM but $35.00 later I would like to be able to clean this one and keep swapping them out.
I do the tap method already, but..
How do you clean these filters?
Do you clean them or do you buy new?
My Dad would have just soaked it in Saw Gas, but...
Adirondackstihl
Photobucket Allstar
Feb 6, 2013
3,476
9,955
Saturate with cleaner such as Simple Green or the like. Let set for 10minutes.
Flush with hot water from the inside out.
IMO, keep the tooth brush away from it
tickbitintn
472
1,684
46
middle tn
i'd stay away from the brush myself... i have had good luck with brake cleaner on the really nasty ones ( spraying from the inside to out)
all the above should work.
axlr8
Simple green for me works best, again hot water from inside out, no brushing, air dry or use air nozzle to help speed the process up..
Carb clean likes to eat certain filter elements.
cat-face timber
Jun 25, 2014
3,458
24,403
Northern Arizona
Thanks for all the information Gentlemen!
I washed the filter in hot soapy water I used dish soap I figured it would cut any oil.
been drying for a day, will check on it tonight.
olyman
5,013
22,336
Thank you for the info Kind Sir!
I do partially like david,,but don't use a brush at all, as nervous of removing the flock material..just let it soak good,,then LIGHT air pressure...the 3120 dilter didn't come completely clean,,but WAYYYYY better than the way I got it!!!!!
67L36Driver
2,321
8,801
St. Joseph, Mo.
Hot water and dish soap. Fifteen minutes on a floor register to dry with the furnace fan set on 'on'.
Our furnace fan runs 24/7. Keeps the basement warmer and dryer. No stagnant air.
nitehawk55
1,788
5,311
SW Ontario
If really dirty I do use a soft only tooth brush a bit but too much use with a brush will loosen the flock ....then you're flocked !! :retarded:
dboyd351
1,788
5,963
Eastern Shore, VA
The USC with a squirt of Dawn will get ti really clean and won't hurt the flocking at all. So unless you really want to get flocked:happygrin:, skip the toothbrush.
echoshawn HomeliteJim is cleaning out his shop... I'm helping For Sale 32
cat-face timber Carb Cleaning Question Chainsawz 66
Specter29 Cleaning House For Sale 12
H 2 H Cleaning Cylinders Chainsawz 5
treeslayer2003 saw cleaning Chainsawz 16
O Cleaning Imac and All-in-one pc's GeekHawgz! 2
Adirondackstihl Window Cleaning Chainsawz 17
WoodChuck'r Cleaning yer stove. Hawgz Back 40 4
TK Carburetor rebuilds/cleaning Hawgz Garage 27
cat-face timber Air compressor question Hawgz Garage 40
cat-face timber Air Comp oil Hawgz Garage 8
cat-face timber Husky 61 Air Conductor needed Wanted 2
redfin NOS 2100 air filter cover Wanted 0
DefinitiveDave odd air filter badge Chainsawz 7
dboyd351 Poulan 245A/306A air filter Wanted 1
Barneyrb Air compressor Hawgz Garage 7
Barneyrb Air Cooled Outboard Wanted 2
J 044 air filter parts trade for 460 filter parts Wanted 1
Duke Thieroff 045/056 Ignition Stuff, Air Filters, Chainbrake, Top Ends, Flywheels, SEM Bosch and Points For Sale 3
BloodOnTheIce 281 Rewind Air Deflector Wanted 5
Eccentric HD Air Filter Elbow for a Husqvarna 268/272XP Wanted 20
Majorpayne Air Horse One The Razorback Lounge 19
M Looking for an air filter cover for a Remington SL4 Wanted 0
Warped5 Need Sachs Dolmar air filter Wanted 19
L Max Flo Air filter material Chainsawz 1
cncman08 Are 056 air filters NLA? Chainsawz 5
bcaarms A breath of fresh air New Memberz Area 5
CBird 026 air leak Chainsawz 17
S WTB: Stihl 460 Air Filter Cover For Sale 2
T 441 air filter cover Wanted 2
C home maed air filters? what do you guys use? i was thinking silk screen like printers use??? Chainsawz 4
M 3120xp filter setup Chainsawz 4
Mastermind Aftermarket fuel filter issues? Chainsawz 9
A Putting an HD2 filter on a carb'd MS362, a how-to. Chainsawz 14
Jimmy in NC 365/372 HD Filter - Convert Low Top to High Top Wanted 2
N stihl 084 hd filter setup Wanted 0
Old Iron Logging Anyone upgrade the 362 filter yet? Chainsawz 0
Chity_Avatar Here is a good deal on a K&N filter for an 084 Chainsawz 8
