1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Compression and leak down test kit
Discussion in 'Hawgz Garage' started by Chity_Avatar, Oct 11, 2013.
  1. Chity_Avatar
    Chity_Avatar Mows his grass in 8 minutes.
    Feb 15, 2013
    5,349
    14,544
    I am looking to get a complete test kit to test compression and do leak down test, both pressure and vacuum. Will a standard pressure leak down tester also work as a compression tester? My compression tester at work is a POS and I need to replace it.
  2. trx250r180
    trx250r180 The Junk Peddler
    May 7, 2013
    7,515
    38,453
    my snap on compresion tester i ,can use the 1 foot hose with spark plug hole fitting on it ,and hook an air hose to it to see if air runs out the intake or exhaust or down to the pan ,no guage to tell you how much if that helps at all ,i think they sell a leakdown tester also with a guage if you need to know how much the cylinder is losing for comparison of other ones
  3. Chity_Avatar
    Feb 15, 2013
    5,349
    14,544
    Just want to be able to test for external leaks like crank seals and base gaskets.
  4. trx250r180
    May 7, 2013
    7,515
    38,453
    like on a chainsaw ? you need to take the muffler and intake off ,a chunk of inner tube and a hose clamp will do the intake,or find something that fits down the intake tight and clamp it ,the exhaust i have seen a metal plate with 2 holes ,will need some kind of gasket or o-ring under it ,the engine builders may have a better setup ,but if you regulate an air hose down t like 5 or so psi it should show leaks without blowing the seals out ,the correct way may be hook a hand held vacuum pump up and create a vacuum and see if drops ,looks like no one working but us today ,maybe someone smarter will chime in ,i just normaly push on the seals ,if they not all soft and squishy ,just replace em they are cheap ,and on stihls can replace without splitting cases
    1 person likes this.
  5. Chity_Avatar
    Feb 15, 2013
    5,349
    14,544
    I have used them before just never had to buy one.
  6. BloodOnTheIce
    BloodOnTheIce ~Ice Gangsta~
    2,034
    2,036
    At the bar.
    I almost never use my vacuum/pressure tester in the shop.
    Very few saws, I work on have air leaks, and the ones that do are usually pretty obvious.
    I only use it to identify where the leak is coming from.
    My right arm, and pulling the muffler is all the compression testing I need.
  7. Chity_Avatar
    Feb 15, 2013
    5,349
    14,544
    All very interesting but how about a saw that nees a top end and doesn't run to see if it has any leaks? How else would I be able to tell if it needed crank seals? The saw in question has crank seals that are hard to come by and if the seals leak then I don't see the point of fixing the top end.
  8. Adirondackstihl
    Adirondackstihl Photobucket Allstar
    Feb 6, 2013
    3,476
    9,954
    Mity-Vac makes a brake bleeder that will show vacuum and bar.
    Whats the saw in question?
    If seals are questionable, just replace em.
    You can use my Snap-On gauges whenever you want.
    maybe you'd like to buy them from me? Lol
  9. Chity_Avatar
    Feb 15, 2013
    5,349
    14,544
    How much?
  10. Termitebuffet
    Termitebuffet For Meals
    Jun 7, 2012
    18,276
    122,582
    Midgetville Norf Kakalacki
