Dead battery on my 2002 GMC pickup
PRJ
The battery on my 2002 GMC pickup was dead this morning such that the electric door locks wouldn't even unlock. The battery in it is less than a year old, so I connected it to a battery charger and seems to be taking a charge.
Since a dead battery has never happened on this truck before, I disconnected the B+ wire from the alternator and connected an ammeter between the B+ wire and the B+ terminal on the alternator and measured a current draw of 0.04 milliamps. I'm thinking that the current draw at the B+ post should be zero.
Do you guys think that I could have a defective alternator where the internal diodes are bad????
nitehawk55
1,788
5,308
SW Ontario
Always some parasitic draw on the battery , I would say yours is normal .
If the battery has gone dead after only one year I would suspect one of the cells has shorted out or your charging system isn't working .
10,734
68,508
Without unhooking the negative terminal, you are still sending current to the computer clock and radio. And a year is more than enough time to draw it down.
Once you get down to around 9-10 volts I'm told the computer will start tripping relays and stuff, hastening the current draw.
nitehawk55
1,788
5,308
SW Ontario
The truck didn't sit for a year , the battery was only 1 year old .
