Headlight restoration
10,260
64,341
#3
Meguiars.
This stuff.
It's around twenty five bucks on sale somewheres. It's an hour project in reality, between gathering the stuff needed and a beer or three, then getting everything put away. Works better on the glass or harder plastics, the thin (GM) not so much. Haze varies after you're done.
But it may take awhile to r & r the assemblies as well.
Get her a new ride, and not a different moostache style kind of ride.
dieselfitter
Aspiring impressionist
Oct 12, 2013
4,102
37,499
Hugo, MN
#5
I bought and used a Krylon kit for my Dodge. Spray on clear. It doesn't last. I don't think I've ever seen anything come out of a spray can with the hardness of headlight plastic.
I sanded the headlights on my Jeep and then heated it with a propane torch to make it clear. It actually worked pretty good. It was really touchy getting it hot but not too hot. I wasn't sure how it would turn out and only did it after ordering new replacements. I would've run them. There were a few spots that I got too hot. I would've sanded them out and re-heated. I have an electric heat gun that I think would be more forgiving.
23,866
165,222
#7
Pics of the wife's dirty headlights?
greendohn
pacing is a way of life
Oct 17, 2013
7,138
63,227
Rush County
#8
Just used the meguires kit on on the wife and daughters pontiac vibes..worked very well, guess we'll sew how long it last.
I had used rubbing compound in the past, it works but doesn't last (either), hoping the UV sealer in the meguires kit last for a while.
jrepairsk70e
20,377
Ulser County N.Y.
#13
3M makes a kit that comes wif a 3"velcro arbor wheel for a drill/die grinder ,,,has sand papers 400 down to 900-1200?grit and some polishing and sealing compounds ,,instructions say its enuf for 2 headlamps but I've already done 4prs ,I'm cheap and usually only treat the area in the center of the focused beam [function over looks] don't really care if the marker/sig area is "clear". Wife took a scotchbrite pad:tears: to the lenses on her Matrix to clean off bugs,,that was a real challenge to repair :facepalm::banghead::oops::thumbsup:
