Nuzzy
Alright, what am I missing... So, I've read all the threads I could, watched the vids I could, and read through all Madsen's literature on this. So here's what I got...
[Using double bevel chisel file]
Suggested angles from Madsen's:
I understand the side of the cutter does the brunt of work, so I start with the Inside Side Plate and go for 45°
Then I line up the small part of the file so my Outside Side Plate is 85-90°. Now Madsen's says the Inside Top Plate should be 40-50°, but that angle seems to me to be a function of the Outside Side Plate angle and it's relationship with the physical file. In other words, if I rotate the file to give a more blunt Inside Top Plate angle, my side plate will change... That said, with the 85-90 side plate, I do feel the top is roughly where it should be.
I aim the file (as I've read) so that I'm just touching the tie strap
So, now I'm in a locked position. I've set the file in three axis: 1) 45° to the bar when looking from above for my Inside Side angle; 2) angled downward so my file corner lines up with the outside corner of the cutter and down to grazing the tie strap; and 3) rotated so the Outside Side plate gets its 85-90°. Now what does this leave me...
An Outside Top Plate angle close to 30-35°, which is certainly not the 15-20° I've read about.
I've been looking at this, trying to figure out how to change things so that top plate angle will lesson, but the only way I can think of involves changing the 45° of the inside side plate.
:retarded: :notsure:
