jimdad07
I'm a big fan of the Alaskan saw mill. I use a Dolmar 9010 with a 28" bar and Woodland Pro ripping chain with an aux oiler. What do you guys like to use?
I hope to get a mill soon. I will be getting a panther mill, but not sure what size yet. Saw will be a 394xp.
iv'e got a norwood mill ,that northern tool sells ,460 or 660 both work good with it ,can mill about 13 feet logs way it's set up right now ,eventually i want to pour a cement slab so can do up to 26 footers
I've got a Granberg NIB that I got last week. Hope to get into milling in the next few weeks.
I've got a Granberg mini mill I've used a couple of times .It's okay to cut a few thick planks but it's a lot of work and slow as a snail compaired to a bandsaw even using a 125 McCulloch or a 2100 S Homelite .
I too, have an Alaskan mill... I run the 9010 with a 36" bar and semi chisel chain filed at 15 degrees.
I wish I had more time to play with it... I have made some 26"x3"x9' Hickory slabs for a friend's bar top.
No aux oiler yet...
