looking for walbro HDA 87 carbs.
Pa.powerchain
ive seen 3 different carbs on 262's the 120,144, & the 87's and im lookin for the 87's (the bore is much bigger). ok, i will check the ones out nate has......thanks.
Pa.powerchain
hey jason.....if its the hda 87.......then id still take it. if you want to part with it.
87's were used on the first 2 years of 262's then 120's. Not sure I saw any others listed on IPLs.... But the computer IPLs skip years assuming there's no updates. So if that helps any, you're looking for 1990-1991, maybe early 1992 262 carbs.
Pa.powerchain
easier to just bolt one on than mess around makin chips........but if it comes to that. i found some other carbs i think will work. the guy claims they were off 262's and they have the same bore as the 87's. im pretty sure they'll work
