McCullough chain keeps coming off help!!
jimmybigfoot
17
9
3
Hi, I have a McCullough mac 444 and the auto tensioner has recently gone on it so I swapped it with a manual tensioner from a similar model ( all the casings and fittings are the same). Anyway since then (last week) the chain has come off 3 times even thought it initially runs fine. It tightens up fine but even when it's tight it still comes off.
Could this be the gear on the back of the clutch which the chain runs on?
Can anyone help?
Jim
68,757
I've never even seen a Mac 444?
jimmybigfoot
17
9
3
Thanks for the replies guys I forgot to mention the I live in France so maybe it's a French market model. I think it's 46cc with a 16"bar
BloodOnTheIce
~Ice Gangsta~
2,087
Parts Unknown
Check the drive links that ride in the bar if the chain comes off they
will develop a bur and won't stay in the bar.
Clean up the bur, and you should be fine.
Spike60
261
519
Just taking a guess here-----------Most chain tensioners have 3 components: The screw, the pawl that fits the hole in the bar, and some kind of nut or washer that keeps the entire assembly from moving back and forth in the saw. I'd say take a look and make sure that the tensioner is secure in the saw.
What you have there is a Poulan of sorts and the bar tensioners are notoriously weak, along with the plastic support in the side cover. I'd be looking for a deformity or a partially stripped screw/nut. It's only a couple bucks to replace the tensioner, and a couple more to replace the entire side cover. I've got one here in purple that would look great on that saw ;)
4,294,967,295
38
Any chance that thing is a Poulan...??
That dawg, muffler, and handle in front of the clutch cover looks awfully "Poulanish".
Could be wrong I guess - just kinda looks like one...
That sprocket looks chewed. Maybe the tensioner screw is stripped too....??
Clutch sprocket, time to go. 530047061 can be had for about $10 if it's the same one. Take a pic of both sides of the clutch cover where the tensioner is if you will. A lot of times what happens with these is the nuts get tightened down prematurely when the bar adjuster isn't in the hole in the bar. This bulges out the section where the tensioner is. That will allow you to put tension on the bar but then as you use it it slips out of place. Technically the bar nut pressure should hold the proper tension, but these setups are terribly efficient and will allow it to slip. The bar adjuster pin is mostly to hold the tension on the bar while you tighten the nuts down - which is similar to the molded flywheel keys, those just hold the correct timing position while you tighten the flywheel nut. The taper fit holds the flywheel in the proper place, not the key.
Nixon Chain question . Chainsawz 52
trx250r180 Stihl usg round chain grinder For Sale 9
cat-face timber Homelite Super XL 925 Bar/Chain Wanted 3
Nickolas Chain parts and pieces Wanted 0
N .063 gauge .325 chain , is it common in the USA ? , I need some Chainsawz 26
2broke2ride ID this chain please Chainsawz 3
N Word is Blount / Oregon chain / bars has been sold Hawgz Back 40 24
S Makita 6401, sugihara 32" bar, how long of a chain? Chainsawz 9
mdavlee Race chain for Jeremy and Shauna Chainsawz 6
Cut4fun Chain build off GTG'z & Eventz 8
Majorpayne Handling Bulk Chain Chainsawz 58
H Chain geekery: Chisel Ground vs Chisel Filed Chainsawz 21
G Need 32" bar and full skip chain Wanted 8
ft. churchill Timberline chain sharpener Chainsawz 5
P Menard's Chain Prices Chainsawz 25
B Wanted 3/4 harvester chain Wanted 7
Magnumitis Chain grinder Hawgz Garage 39
DefinitiveDave Franzen sharpener, stihl service clinic, safety chain, counterfeit saws, etc. Chainsawz 31
C Chain Saw Industry magazines Chainsawz 1
B General 60 inch bar and chain for Homelite For Sale 1
BloodOnTheIce Homelite 340 with 16" bar and chain For Sale 5
BloodOnTheIce New 36" Stihl .404 .063 Semi Chisel Full Skip Chain For Sale 3
Wood Doctor Stihl 028 and Chain Pitch Chainsawz 23
S 028av chain brake wanted Wanted 1
P Greg Norman recovering from chain-saw accident The Razorback Lounge 2
B Stihl 020t Stuck chain adjuster Chainsawz 0
Black Dog Chainsaw .325 058 chain - 100' roll or loops For Sale 0
Black Dog Chainsaw MacCulloch .354 chain For Sale 1
R Stihl Chain... want some , at pretty good prices? Chainsawz 14
L Chain Identifcation Chainsawz 1
DefinitiveDave NOS Stihl RS2 3/8" .063 chain For Sale 3
trx250r180 chain grinder For Sale 17
axlr8 Chain sharpener. Wanted 22
fossil Trying to locate some .404 X .058 chain Chainsawz 14
50blues wanted Stihl ms250 ez start recoil and tool less chain cover Wanted 0
C whos got the best price/value on 13" or 15" guide bar and chain for my 024 stihl ??? Chainsawz 18
P Bar and Chain Oil Jugs Chainsawz 60
H Oregon 511AX chain vise bed Wanted 8
griffonks Stihl chain roll prices Chainsawz 31
P Closeout Deal on a Couple of Carlton Chain Reels Chainsawz 10
griffonks Chain spinners and breakers Chainsawz 48
N Bench mounted Chain Grinders....what are you usiing ?? Chainsawz 62
H 2 H Anyone need a chain sharpener ? Chainsawz 13
Freehand Anybody Know Where A Feller Can Get A Full House Chain For One O Deez? Chainsawz 33
Chity_Avatar Please evaluate my chain Chainsawz 13
PA Dan 026 chain brake parts Wanted 10
Mastermind Who has the best prices on rolls of chain???? Chainsawz 33
S Likes, dislikes of the "triangular" files for square filing chain? Chainsawz 28
Chity_Avatar Electric chain sharpner wanted. Wanted 11
Poncho Husqvarna to manufacture chain?? Chainsawz 10
