ms200t throttle linkage
DefinitiveDave
I do want to see skinny guys in speedos
Oct 24, 2013
2,310
18,313
I must be the most ham fisted hawg in existence, I spent a good 15 minutes trying to get the new carb installed on a customer's MS200t with the throttle linkage (orange plastic and brass rod only) and then finally gave up and rebuilt a 460 instead. I am pretty sure I have everything I need to build 10 more 200ts sitting here in the bins, but just cant get motivated, there has to be some secret to getting these linkages together without wanting throw the saw at a wall.
Also If anyone has a line on AV Mounts and or Intake manifolds at a reasonable price OEM or AM I am very interested.
DDave
griffonks
11,652
100,107
Tricky but this tutorial is pretty good .
http://www.youtube.com/watch?v=duomigDd2Ug
That's how I learned. Start the carb down the posts. As the carb enters it's housing grab the throttle linkage with a pair of NN pliers and pull it through the throttle linkage, then push the carb almost all the way back and attach the fuel hose. After the carb is seated attach the choke linkage, done.
After you get it it takes seconds.....
I'm waiting for a fuel tank vent assy for mine....
Reactions: jrepairsk70e
Paincow
437
Apr 23, 2014
6,122
21,395
Scroll down youtube channel "donyboy17" video list until you see a video about this saws linkage. I just watched it the other day but couldn't get the video to link. He had the same issue.
Reactions: Majorpayne
czed
Orders his shit fire from Amazon
Aug 30, 2014
14,907
164,976
DDave
Bump
