Poulan thread
Sep 29, 2013
11,172
71,254
...think we need one here4200 570 001.jpgpoulan 4200 002.jpgpoulan 4200 001.jpg 4200 was 1st saw I ever ran, back "78-79. they were new then... that's not the one in pics... got it couple months ago... pete.
14,254
68,625
Sep 29, 2013
11,172
71,254
4200 tank vent
anyone know about tank vent on it? when on its side, getting fuelled up, cap off, is leakin gas all over, fill & put cap back on, it stops... some one have ipl or ideas? runs good on its side so not thinkin carb. TIA...
14,254
68,625
Easy fix. Go to your Husqvarna dealer and get a 530026119 'duck bill' valve. Should be around $3.
Remove the AF cover and AF. Look behind the carb (close to the rear handle) for an aluminum fitting that may or may not have a little hose sticking out of it. It is threaded into the top of the fuel tank.
Unscrew the fitting and clean all the melted black duckbill remains from it. There's a nipple on the underside of the fitting. Once you have it all cleaned up, slip the new duckbill onto that nipple.
Thread the fitting back into the tank and go cut wood.:thumbsup:
Sep 29, 2013
11,172
71,254
thanks, aaron. pete. edit: was not vent, but fuel line thru top of tank, fixed, thanks again. p.
Cattoon
5
1
3400 seal numbers
I had a couple of links to crossed seal numbers for 3400 on AS, we know how that turned out......... Does anyone by chance know the national # , and would you please post it. I have a winter project.
14,254
68,625
The SKF # is 6119. National/Timken is 253747.
