Redneck Case Splitting
motomedik
92
62
Soooooo, I was asked to "pop" this 395 lower end and thought I'd throw out some pics. Here's my method, feel free to ad your wisdom gents!
The top end is off, as well as the fuel tank, top handle, and the clutch side is stripped, oil pump removed, the flywheel removes on a huskie with this;
I use the screw holes from the starter pawls and a simple puller (steering wheel or harmonic balancer)
Next thing is to remove the case screws (DUH) but the tools work better when you DIG the gunk out!
And then the screws all come out- even the hidden ones! Now we dig throughout the mess I work in and around and try to find the "case Splitter", a tool that has been fabbed and gets modded as needed to suit each job, the idea being not to render it useless for given task, only adding to the usefullness. This time a notch for clearance was added. No fancy machining at my place- drill press, angle grinder and a welder.
motomedik
92
62
Once the thing is split, the next step is removing the crank. Generally one does not want to pound things apart, this arbor press was spotted in the scrap dude's truck- bought it for twenty bucks. Apparently he found the thing was handy to remove bearings and such from cases making his "dirty" aluminum clean. One bearing being stubborn, he took to pounding at the top of the ram. The bearing gave up the fight and the handle came 'round and made him forget what he was doing for awhile-:retarded: got a good thump in the top of his head! And so it went in the scrap pile...I find it SAVES me headaches:rolleyes2:
motomedik
92
62
Anyway, once I get the crank out, the bearings and seals get pressed out and then the thing gets to take a bath! Clean it up and scrape the gasket, need parts now!
motomedik
92
62
I try to build tools as needed if possible. Threaded pullers must be bought, but things like that I just copied the stihl tool in that case.
Kind of surprised me, honestly, the thing worked that well being that it attaches on the bar studs only and so only to the one side of the crank. Not huge force required, and a soft hammer evens things out. I've used it on the 395, 272, 262, 460, now and works well.
Termitebuffet Redneck Mama Woodz Porting & Saw Buildz 207
K Got any redneck log trailer/forwarder ideas? Hawgz Back 40 33
Homelite410 Too redneck? Chainsawz 17
rocketnorton 395 case Hawgz Back 40 16
jacob j. Husqvarna 394/395 case half or crankcase Wanted 1
cus_deluxe 395xp PTO side case half Wanted 2
EvilRoySlade 357 clutch side case Wanted 0
Red97 346 351 353 clutch side case Wanted 6
Mastermind Bar Studs Stripped Out Of Case......How To Fix Chainsawz 52
DefinitiveDave in which i admit a case of dumbz Chainsawz 16
cat-face timber I need a Husky Case Splitter Chainsawz 25
struggle mix match cranks case stihl 460 Chainsawz 4
DefinitiveDave Pro Tip on case splitting Chainsawz 27
Genius picture of a 044 case splitter needed Chainsawz 4
H stihl crank case corrosion Chainsawz 14
H Clutch drum rubber a hole in my case....is it ok Chainsawz 6
Chity_Avatar Stihl 028 case gasket Chainsawz 15
H want to buy a ms440 case half(clutch side) Wanted 0
Windthrow Win a case of .223 ammo Firearmz, Hunting, Camping, Fishing, Countryside, 0
Whitedogone case split without doing seals, etc Chainsawz 7
Little Possum best sawhawgz approved phone case GeekHawgz! 19
jacob j. Wanted- Husky 394 or 395 PTO side case half Wanted 0
N Case splitter for Husky 359 Chainsawz 0
W Natural Selection Moment....or a case for a Smith M&P vs a Glock Firearmz, Hunting, Camping, Fishing, Countryside, 10
Warped5 Unused DeWalt sawzall case ... Wanted 5
komatsuvarna WTB 372 case Wanted 2
Adirondackstihl Case Splitter Hawgz Garage 56
mweba Splitting a case with homemade tools Hawgz Garage 9
B 2100 Case For Sale 3
trx250r180 Firewood Splitting Axe's Hawgz Garage 26
dboyd351 Fiskars Iso core 8 lb splitting maul Hawgz Back 40 12
W Splitting cases with a specialized tool & misc. stuff, home made pile to put things back together Hawgz Garage 2
WoodChuck'r Started splitting this season.... Hawgz Back 40 21
TK All things splitting Hawgz Back 40 25
