Square Grinding Questions
Troy G
237
43
For the people running square grinders or for people who just know.
How thick are you leaving your grinding wheels or how far down does your stone cut the side plate.
How far down the side plate needs to be ground?
I am trying to convert round to square and would like a wheel that is great for removing material without heating the teeth. I have Salmon which I dressed pretty thin, Blue Ceramic which needs to be dressed a little further as it cuts into the back tie strap a little, and a White, yet to be dressed. All the wheels are from Madsens.
I am trying to go slow as I am used to running a 510 with a CBN wheel and I have yet to heat a tooth with those.
I am using a used Pro Sharp but I am not sure if the grinder could use some service or not.
47,584
I run my wheels where the side plate flat is around 3/32" thick. I touch the tie straps when I grind but not too deep. I usually just cut with the chains with the first grind and when they're dull I'll grind them again and they'll be more of a square profile. A lot of times the first grind is still a lot like round with the corner and top plate the only thing the wheel touched. :cheers: Just send the pro sharp on down and I'll take care of it and see if it needs work:santabanana:
Reactions: 4 people
Troy G
237
43
I believe that is my problem. I am taking too much of the wheel to the chain to try to get rid of the round profile and make it look like square right away.
47,584
Just take little bites if you want to get it all the way to a square profile. It will take 3 rounds usually for a brand new chain to get the right profile from round. I usually go around once maybe twice if I'm not busy or in a hurry.
Troy G
237
43
Yeah thanks Mike. I am trying to cut too much and even though I am just pecking at the cutters I still getting too much heat and need to do what you suggested. With the CBN wheels on round you can remove a lot of material quickly without getting the heat. Too used to that. Need to slow down.
47,584
I've never used a round grinder with one of those wheels so I don't know what to compare it to. I've heard they're awesome and wish they would make something similar for the square grinders.
Troy G
237
43
Even when I first got my round grinder I blued some teeth trying to figure out how fast was too fast. Seems I need to learn that again. Also learnt clean cutters is important as well.
Yeah a CBN wheel for square would be neat but it would also lock one into specific grind angles. At least with a dressable stone the angles can be changed.
47,584
If you could get a stone made for a set of angles for say a good work grind then it would probably be worth it. For playing with chain for racing it wouldn't be a good thing since you couldn't change the wheel angles.
Troy G
237
43
Yeah I am grinding at the recommended medium on the pro sharp and don't have any urge to get really crazy with the angles, yet. I need to learn how to make a good work chain first. I wonder if US Diamond wheels could make something? Might be hard to keep the crisp angles required for square? Why not a 200.00 plus wheel to go with and extremely expensive grinder? :laughing:
47,584
Yeah I would think a stone like that probably couldn't get a super crisp corner like you can with dressing on a regular stone. I like the ceramic for production grinding work chains. It will last a good bit longer than a salmon wheel.
Troy G
237
43
I am going to dress my white stone and give that one a whirl. I am going to save my Blue Ceramic for touch ups instead of shaping:meh:
47,584
The white will burn a tooth quicker than the salmon so keep that in mind. The ceramic is good for when you're not changing angles any and just dressing a little and grinding.
47,584
Converted this one over this afternoon.
There sure is a learning curve, lemme tell ya!
Looks like you need another degree or two on the side plate to get it to have a little forward lean. It looks like the corner is behind the rest of the plate just a touch.
If you have the dimensions you can have a wheel made for you Cbn. It might have been us diamond, there was a guy on as that was a rep and for the life of me I can't remember his name. They can customize round wheels for different profiles if you wanted, I'd imagine square is also doable.
47,584
I guess it was good. Those side way pictures mess with me.
Troy G
237
43
I thought the same thing but figured it could be the lighting. Bummer on the White stone. I will cut with the Salmon and then when i have more square profile I will use the blue ceramic. Think Salmon is the best, then?
TK Square grinding chains Chainsawz 191
K Why are planets round, not square or trapezoidal shaped ?? The Razorback Lounge 12
Nixon Square filing ..... Rakers ? Chainsawz 4
S square files Wanted 6
S square guide Wanted 1
mdavlee Square filing videos Woodz Porting & Saw Buildz 57
S Likes, dislikes of the "triangular" files for square filing chain? Chainsawz 28
Nuzzy Help tweak my square filing Chainsawz 17
S A question about files for square ground chain sharpening Chainsawz 10
H 2 H TRX square files Chainsawz 3
Mx_racer428 .050 half skip square grind? (RSLHK) Chainsawz 8
trx250r180 Square chain sharpening tips Chainsawz 362
TK Square filing Chainsawz 180
Majorpayne CBN Grinding Wheels For Sale 12
T Sling'rs Professional Grinding Chainsawz 74
Watsonr Silvey 300/500 grinding wheels Chainsawz 2
Majorpayne Chain Grinding Chainsawz 34
Hedgerow Outboard Motor questions Firearmz, Hunting, Camping, Fishing, Countryside, 43
M 3120xp questions - crank bearings and oil pump Chainsawz 11
H Stihl 046 post piston change questions Chainsawz 5
WOODS The Chump is Stumped. 4 stroke questions. Hawgz Back 40 35
DefinitiveDave way too long, no need to read unless you like boring crap, dumb questions and free stuff Chainsawz 30
TK standard and not so standard gun questions Firearmz, Hunting, Camping, Fishing, Countryside, 37
Chity_Avatar The 075 is in pieces, now a couple of questions Chainsawz 25
0 d5 xl high track clutch questions. Hawgz Back 40 11
DefinitiveDave This weekends buys and a few Stihl questions Chainsawz 0
DefinitiveDave workin on a bunch of stihls at one time, a few questions Chainsawz 31
Fish Basic Chainsaw Questions Site Info, Tech Support, & Suggestion Box 2
originalrebel chainsaw mill questions Hawgz Back 40 8
naked arborist questions 101 The Razorback Lounge 22
K newbie intro and questions Chainsawz 10
