What size fuel hose for McCulloch Titan 57 ?
nitehawk55
SW Ontario
My son just got one he's tinkering with but using google we are getting conflicting sizes and not sure what to use .
Looks like you use 3/32 ID and 13/64 OD ? Is this the correct type of hose ??
Red Dawg
Is it necessary to have the line with the coiled inserts? Seems all tight turns are sorted with plastic elbows
Sent from my iPhone using Tapatalk
nitehawk55
SW Ontario
I see my son Red Dawg has signed in so i'll leave him to the experts .
Yes , I'll agree on the paperweight comment there Rich
In my experience, no.
The Titan 57 is the perfect saw to have up in the bucket, you don't feel so bad if you happen to drop it.
The only line I can read anything on says 1/4"O.D. I don't remember now if all of the lines are the same size, or if you have to use different sizes.
Red Dawg
I ended up using some stihl line - although I believe the OD might be a bit loose going through the oil/gas tank holes
From the pics, it looks to me like Mark and Mitch used 1/8"ID x 1/4"OD line. .117"ID x .211"OD would probably work fine too.
